Switch:1#show ipv6 source-guard interface gigabitEthernet 1/1
Slot/Port Source Guard Number of IPv6 Address
Mode address allowed overflow count
1/1 Enabled 4 0
Switch:1#show ipv6 source-guard interface enabled
1/1 Enabled 4 0
1/2 Enabled 9 0
The following table defines parameters for the show ipv6 source-guard interface gigabitEthernet command.
Variable |
Value |
enabled |
Displays IPSG configuration on all IPSG enabled interfaces. |
gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Displays IPSG configuration on the specified interface. Identifies the
slot and port in one of the following formats:
